admin ارسال شده در جولای 14 2022 ارسال شده در جولای 14 2022 Application and benefits of Silica Helix and Block Helix What is Heplex Silica? Silica is one of the most widely used minerals found in the earth's crust. This material has a great impact in various industries. Of course, note that this material is also used as one of the most essential minerals for the body. Considering that this substance is necessary for the body, you can use this mineral substance in many foods to supply the energy you need throughout your life. We would like to explain about silica and its uses, as well as Helix silica. What is silica and what is its use? Silica is one of the most abundant minerals in the earth's crust, which has many uses. If you want to use silica in industries, you must use the best and highest quality silicas. First grade and second grade silica, each has various uses. Silica has the chemical formula Sio2 and is one of the best materials extracted from the mine. For this reason, it has many uses. Silica is used in agricultural land, silica in rice, Silica Hablex is used in construction and various industries, as well as providing energy and immunity First-grade, second-grade and premium silicas are among the best sellers on the Hamedan Silica site. Usually, premium silicas are used in glassmaking, chemical, aquarium, artificial stones, glazing, etc. industries. In the following, we will name some of the most commonly used examples of using silica. Farmland Chemical fertilizers Ceramic making Glasswork chemical industry Casting construction Optical fibers What is Heplex Silica? And what are its features? Now that you are familiar with silica, it is time to answer the question "What is Silica Heplex?" to answer Heblex Silica is a type of concrete used in construction. Due to its compounds, it greatly increases the resistance of the building. The high resistance and low weight of Hablex is one of the most important features that are mentioned. One of the most important things that we can mention to show the resistance of this material is its high resistance to fire. Among the features of this material, we can mention the following. Insulation against moisture and freezing Insulation against high noise Fire resistant Earthquake Resistant What is the use of Heblex Silica? This material can have low reactivity against high temperatures and sounds. The most common uses of Hablex are the use of this concrete in the walls of a building, for this reason there is no need to use insulation in buildings. So without a doubt, the most important feature that we can point to is high security and resistance in construction. Helex has great resistance against earthquakes and can be the best protector against heat, cold and sound. You can use concrete and Hebelx in construction at a higher speed. What is the Hublex block? Hablex block is one of the most practical and advantageous construction tools. Heblex Block or AAC Block is made of elements such as cement, aluminum lime powder, water and heblex silica. These elements are exposed to very high autoclaved pressure and heat, and then they are cut into suitable dimensions and ready to be offered to the market. Because of its numerous and unique advantages, Heplex Silica Block is competing with other bricks and construction materials and is one of the popular construction tools. This block has a very low weight and therefore its transportation process is easier than other building blocks. Among the other advantages of this block (heblex silica) can be mentioned the ease of installation and implementation, high resistance to moisture and temperature, plasticity, etc. The last word about Heblex Silica The production and sale of first-class and high-quality silica has many stages, and its production process must be done well by companies. The importance of updating the devices needed to produce this mineral is also very important. Hamadan Diamond Powder Company is proud that it has been able to take over the majority of the sales of this product, both inside the country and in neighboring countries. Consultation and guidance in product purchase, production and sale of minerals (silica, calcium carbonate, dolomite, feldspar) is one of the main activities of this company. To buy silica and other products and minerals of this company, contact our experts or register your purchase order through the purchase form.
