Silica in toothpaste
Regarding the use of silica in toothpaste, it should be said: micronire silica has become one of the most widely used elements in the industry due to its special characteristics and high abundance in the earth's surface. In such a way that it can be traced in all industries, from making cement to making paste. You can refer to the Hamadan diamond powder website to find out about the online order price. Also, if you are interested in getting more information about Hamadan silica and its uses, you can visit the silica production factory article.
Ingredients needed to prepare toothpaste
To produce toothpaste, there is a great need for materials such as silica, which is abrasive. This type of material is used as the raw material for making toothpaste. Because these mostly inorganic materials destroy the components attached to the surface of the teeth without reducing the natural polish of the teeth.
Why use silicate in toothpaste?
Micro silica is extracted from ore. Then it is turned into various fine grains by means of different mills. Due to the high quality and efficiency of silica in industries such as; Dental health is used. In the continuation of the article, we will use this type of silica for the toothpaste industry.
toothpaste silica; A strong abrasive
Silica is used as an abrasive in toothpaste. Abrasive silica in toothpaste helps prevent stains from remaining on tooth enamel. In some toothpastes, they do this by using whitening materials such as: hydrogen peroxide.
But the use of these materials only changes the color of the teeth. And it does not help to remove stains from the tooth surface. However, silica has high stain removal and scale removal efficiency; In such a way that its combination with toothpaste makes the toothpaste more effective.
the enemy of tar tars; Strong cleaner
The mixing of oral bacteria with various drinks and foods leads to the formation of dental plaque. which gradually turns into a harder material called tar tar. The important thing is that you cannot remove tartar yourself and you need a dentist to fix it. Because it will lead to tooth decay over time.
Regarding abrasive silica in toothpaste, you should know that; Silica, in addition, stain removal properties; Protects teeth by polishing. that too without scratching the teeth; So, silica can be the first class enemy of Tartars.
The safest toothpaste
silicon has extraordinary physical and chemical properties; which encourages people to use silica toothpaste. This substance is composed of Chinese herbs, spices and fluoride, which is usually used in toothpaste; It does not show any chemical reaction. On the other hand, this material does not have any negative reaction on saliva and mineral water. These things have made silicate the best and safest addition to toothpaste.
Other uses of silica in toothpaste
The mentioned cases were only part of the benefits of silica toothpaste. Its other advantages are as follows:
    Toothpaste concentrate
    Toothpaste stabilizer
    Stabilization of fluoride
    Preventing tooth decay
What is the proper size of silica grains in toothpaste?
As stated earlier. Silica is extracted in the form of rock and then it is cut into different sizes and required in the factory. But what are the proper dimensions for using silica in dental care? In answer to this question, it should be said: Silica powder should not be in such a way that its grains can be felt in the mouth. It should not feel like: a foreign substance. Rather, it should be a mixture of the same main ingredients as the toothpaste.
Suggested article: "What is silicon dioxide"
Final word:
Regarding silica in toothpaste, you should know that: in general, micronized silica due to its internal characteristics and its abundance; It is the most widely used material in the industry. Silica due to having features such as; Concentration, prevention of decay, lack of negative reaction with other materials, abrasion, etc., is considered one of the best materials in making toothpaste. You can get all kinds of silica from Hamedan by referring to the site of Azarin Almas Powder in Hamedan, which is one of the silica production factories.
The production and sale of first-class and high-quality silica has many stages, and its production process must be done well by companies. The importance of updating the devices needed to produce this mineral is also very important. Hamadan Diamond Powder Company is proud that it has been able to take over the majority of the sales of this product, both inside the country and in neighboring countries. Consultation and guidance in product purchase, production and sale of minerals (silica, calcium carbonate, dolomite, feldspar) is one of the main activities of this company. To buy silica and other products and minerals of this company, contact our experts or register your purchase order through the purchase form.
