admin ارسال شده در جولای 14 2022 ارسال شده در جولای 14 2022 silica Difference between Silica and Quartz: Silicon exists as its oxide in nature. Silica with molecular formula SiO2 is the most common silicon oxide. Silica is an abundant mineral in the earth's crust and is found in sand, quartz and many other minerals. Some minerals contain pure silica, but in others, silica is mixed with other elements. In silica, sulfur and oxygen atoms are joined by covalent bonds to form a large crystal structure. Each sulfur atom is surrounded by 4 oxygen atoms. Silica is not conductive because it has no electrons to move. In addition, it is highly stabilized, the melting point of silica is 1710 C and it cools at a certain rate and the fused silica solidifies to form glass. Silica does not react with any acid except hydrogen fluoride. Silicon is prepared using Hamadan silica in a commercial furnace in the form of an electric arc. Silica is very abundant in the earth's crust and is also present in significant amounts in our bodies. Silica is needed for the healthy maintenance of bones, cartilage, nails, tendons, teeth, skin, blood vessels, etc. This material is found naturally in water, carrots, bread, raisins, etc. Also, silica is widely used in ceramic, glass and cement industries. In this article from Ara Seng Alvand site, you can read about the uses of silica. Quartz Quartz is one of the pure samples and a mineral that contains silicon oxide and the chemical formula SiO2. The unique crystal structure of quartz collides with the 4-sided spiral chains of silicon. It is the second most abundant mineral in the earth's crust and has a wide distribution. Quartz is part of all three types of metamorphic, igneous and sedimentary rocks. Quartz can vary from one place to another according to its color, transparency, amount of silicon dioxide, size, ingredients, etc. These can be colorless, pink, red, black, blue, orange, brown, yellow and purple. Some quartz minerals can be translucent, while others are translucent. Citrus, amethyst, milky quartz, rock crystal, rose quartz, smoky quartz, and prasiolite are some of the types of large crystal quartz. Quartz is mostly found in Brazil, Mexico, Russia, etc. There are significant morphological differences in different quartz minerals. Therefore, they are used as ornamental stones. It is considered a semi-precious stone and is used in making ornamental jewelry. In addition, due to the quality of the quartz formula, it is also used in ceramics and cement due to its high thermal and chemical stability. Advantages of quartz glass Quartz glass is widely used in laboratory applications. The constituent elements of this type of quartz glass are brusilicate. The features and benefits of this glass are: high resistance Heat resistance Chemical purity Appropriate thermal expansion coefficient Permeability Corrosion resistance Electrical insulation High optical transmission Helping to make lenses and epitopic objects Physical properties of quartz Quartz is actually another type of brocyclate, which is a stable element in terms of physical properties and is used in various cases. We humans use this element abundantly every day, but we are unaware. Among the physical properties of quartz glass, it is possible to mention the manufacture of wall and wrist clocks, which are a widely used device in every person's life. In the article on the difference between silica and quartz on the online sales site Silica Ara Seng Alvand, you were told about the characteristics of silica and quartz, and we hope that you can fully understand the difference between these two models and know that each of them has very important parts in Industry is used. Some related content: What is the difference between silica and silicate? Micronized silica in the artificial stone industry Applications of micronized silica Reaction of silica with acid Micronized silica packing What is quartz plate (black and white cabinet quartz stone) Quartz Plate Silica: Silica is synonymous with silicon dioxide (SiO2). Silicon and oxygen are two abundant elements in the earth's crust. Silica is usually found as sand in nature and exists in different forms, which can be crystalline as well as non-crystalline (amorphous). Hard crystalline silica is chemically inert and the melting point of quartz is 1650 degrees Celsius. These are valuable qualities in various industrial applications. In order to know more information about silica and silica for pool water purification, its features, you can read the silica production factory article from Arasang Alvand website. Quartz plate silica is the most common form of pure and crystalline silica and is the second most common mineral on Earth. It is found in almost every type of rock such as igneous, metamorphic and sedimentary. Because quartz is so abundant, it is present in almost all mining operations. Now, stay with us so that in this article from Arasang Alvand site we will take a complete review of Silica Quartz. Water purification silica and filter sand! Quartz page silica, a topic that Arasang Alvand site intends to explain to you in this article. I hope that these explanations can help you a lot to know about buying different types of silica. What is silica: Silica is a type of mineral whose ingredients are silicon and oxygen. The mass of the earth's crust consists of 59% silicate. Silica stone is used in water purification and quartz with 99% purity. Silica has many uses, for example: in glass industry, Freezing, ceramics Quartz is a hard, crystalline mineral composed of silicon and oxygen atoms and the second most abundant mineral in the planet's crust after the feldspar family of minerals. Quartz is the defining component of granite and other felsic igneous rocks. It is common in sedimentary rocks such as sandstone and shale as well as schist, gneiss, quartzite and other metamorphic rocks. The process of creating silica quartz plate Silica is a form of silicon dioxide (SiO2) and occurs naturally as quartz. While beach sand is also mostly quartz, the most common raw material for electronic grade is high purity quartz rock. The steps of this process are as follows: Ideally, silica has low concentrations of iron, aluminum, and other metals. Silica is reduced by reacting with carbon in the form of coal, charcoal and heating to 2000-1500 degrees Celsius in an electric arc furnace (oxygen is removed); SiO2 + C → Si + CO2 changes based on this formula; The obtained silicon is metallurgical grade silicon (MG-Si). It is 98% pure and widely used in the metallurgical industry; Even more silicon is produced in the form of ferrosilicon, which is produced using a process similar to that described above, but using iron oxide. Ferrosilicon is widely used in the production of metals. In 2013, the total production of silicon was 7.6 million tons, of which 80% was ferro-silica. Therefore; Metallurgical silicon (MG) is produced at the rate of millions of tons per year with low economic cost and energy cost of 14-16 kWh/kg. Silicon production to produce quartz plate silica Most silicon is produced as a ferroalloy of ferrosilicon or silicon manganese, which is used exclusively in steelmaking. Silicon, as a ferroalloy, is the most important oxidizer in steelmaking. Semiconductor silicon is mostly made by reacting raw metal powder with a gaseous mixture of hydrogen and hydrogen chloride in a fluidized bed. The original SiHCl product is fractionally distilled and then reduced by hydrogen and then deposited on a pre-silicon filament heated to about 1150°C. If necessary, the silica of the quartz plate may be further treated with zone purification. Detergents are generally added after crystal growth. Silica measurement of quartz plate Cabinet quartz stone coloring: Because silica is not freely available in nature, the measurement of silica in water or other compounds can be measured in the form of free silica (SiO2) in large-grained quartz and fine-grained quartz (flint, jasper, etc.). . Due to the fact that quartzes are diverse, but their main constituents are sand, sand and boulders. In the compounds of silicates and other metals, the abundance of silicon (Si) is evident. It should be noted that silicate is found in rocks such as granite, basalt, etc. For this reason, silicon Si can always be measured in the form of (SiO2) in soil, water and sediments. The amount of silicate in the rocks is different and ranges from 7 to 80%. It is also evident in simple soils between 50 and 80% and in underground water it is approximately 14 mg/liter. The measurement of silica in water by the Molybdosilicate Method is applicable according to the standards of the method. ?What is silica in water In water, silica is available as H4SiO4 and H3SiO4. Silica in the vicinity of magnesium may form deposits and settle in steam turbines or boilers. On the other hand, silica is known as a traceable, unnecessary metal all over the planet, but the measurement of silica in water, soil, and food is necessary for the environment of animals and in their bodies because some of this silica are carcinogenic. It should be noted that in the standard of EPA and others, the amount of silica in drinking water is not mentioned Suggested article: "Silica for swimming pool water purification" What is Silica Quartz Plate? Quartz, as mentioned above, is one of the purest examples of naturally occurring silica. Quartz is a crystalline solid, meaning it has very distinct properties from glass while still resembling glass in chemical composition and appearance. There are limited industrial applications of quartz (meaning crystalline mineral). However, quartz crystal oscillators are found in electronic systems. Where is quartz found? (black cabinet quartz stone) It is the most abundant and scattered quartz mineral that can be found on the surface of the earth. It is available and abundant in all parts of the world. It forms at all temperatures. And it is abundant in igneous, metamorphic and sedimentary rocks. It is very resistant to mechanical and chemical weathering. This durability makes it the dominant mineral of mountain tops and the main constituent of beach, river and desert sand. Quartz is ubiquitous, abundant, and durable. Mineable deposits are found all over the world. ?What are the characteristics of silica quartz plate Silica quartz plate feature row 1 has a rough surface and is not slippery at all 2 It has a very high electrical resistance 3. It has high resistance to chemicals 4 It also has a very high resistance against thermal shock Quartz plate silica applications in various industries (cabinet quartz stone sales representative) Applications of quartz sand Quartz sand is used as a filler in the manufacture of rubber, paint and putty. Screened and washed quartz grains of precise size are used as filter media and roof granules. Quartz sands for traction in road industries Iron and ore are used Application of quartz in glass making Quartz Plate Silica: Geological processes sometimes deposit sands that are almost 100% quartz grains. These deposits have been identified and produced as sources of silica sand with high purity. These sands are used in the glass industry. Quartz sand is used in the production of container glass, flat plate glass, specialized glass and fiberglass. Application of silica quartz plate as an abrasive The high hardness of quartz makes it harder than other natural materials. As such, it is an excellent abrasive. Finely ground quartz sand and silica sand are used for sandblasting, wash cleaners, grinding media, and sand for sanding. Special applications of silica Silica is an industry term for materials such as quartzite, novacolite, and other microcrystalline quartz rocks. These are used to produce abrasive tools, abrasives, grinding stones, oil stones, stone files, pipe grinding liners. Buy silica The production and sale of first-class and high-quality silica has many steps, and its production process must be done well by companies. The importance of updating the devices needed to produce this mineral is also very important. Hamadan Diamond Powder Company is proud that it has been able to take over the majority of the sales of this product, both inside the country and in neighboring countries. Consultation and guidance in product purchase, production and sale of minerals (silica, calcium carbonate, dolomite, feldspar) is one of the main activities of this company. To buy silica and other products and minerals of this company, contact our experts or register your purchase order through the purchase form.
